  • 1.  AOS-10 with central firmware downgrade
    Posted Nov 29, 2023 05:49 AM
    Environment:
    AP Model : AP-535
    Gateway Model : A7220
    AP Firmware : 10.3.1.3
    Gateway Firmware : 10.3.1.3
    Deployment Mode : Tunnel
    I am upgrading both gateways and AP's to 10.4.0.3. I understand the upgrade process, however I have a question related to downgrade. As part of contingency planning, we always document how to downgrade. I went through the release notes and central user guide but could not find a procedure to downgrade. In AOS-8 one could easily downgrade using following procedure.
    select the desired partition.
    (host) # boot system partition 1
    Reboot the controller.
    (host) # reload
    How can I achieve this using central and aos-10. Can anyone please point me to documentation showing firmware downgrade procedure.
    NadeemNet
  • 2.  RE: AOS-10 with central firmware downgrade
    Posted Nov 30, 2023 11:00 AM
    When running the upgrade through Central you can choose a specific partition for the upgrade.  Downgrade is either going through the CLI as you've already noted or running another "upgrade" with the old firmware version.
    Carson Hulcher, ACEX#110
