Wired Intelligent Edge
AOS: 2930F/2930M: Maximum number of LACP trunk group
  • 1.  AOS: 2930F/2930M: Maximum number of LACP trunk group
    Posted Mar 28, 2019 09:32 PM
    Hi Team,
    Good morning.
    Just wanted to check what is the maximum LACP Trunk group you can configure for the 2930F and 2930M switches.
    Some weblink showing it to be 8:
    https://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/LACP.php
    While the user guide shows 60:
    Aruba 2930F / 2930M Management and Configuration Guide for ArubaOSSwitch 16.06 (page 144)
    Please advise thanks!
    -Ricardop
    #2930M
    #2930M
    #2930F
  • 2.  RE: AOS: 2930F/2930M: Maximum number of LACP trunk group
    MVP GURU
    Posted Mar 29, 2019 01:22 AM
    Always refer to ArubaOS-Switch documentation for Aruba 2930F or Aruba 2930M: 60 seems a reasonable value.
    Your first link refers instead to ArubaOS (which is not equal to ArubaOS-Switch), an operating system used on Aruba Wireless Controllers or (now superseded) Aruba Mobility Access Switches (MAS).
  • 3.  RE: AOS: 2930F/2930M: Maximum number of LACP trunk group
    Posted Mar 29, 2019 04:31 PM
    Greetings!
    The maximum number of trunks (LACP or static) that can be configured on the 2930F and 2930M is 60, with up to 8 ports per configured trunk. Note that this number is the same for standalone and stacked (VSF or backplane stacking) switches — it does not scale with the number of stack members.
  • 4.  RE: AOS: 2930F/2930M: Maximum number of LACP trunk group
    Posted Apr 01, 2019 12:12 AM
    Hi Team,
    Thanks for clearing it up for me and will follow the user guides.
