Yes it does, while in AOS8 the scalability is much higher.
Please note that that
AOS6 is end of life and end of support, which means that you should not deploy it anymore. Best is to work with your Aruba partner to get you going.
Original Message:
Sent: Feb 01, 2023 02:34 AM
Subject: AOS 6 EOL/EOS
Hi All,
As I am unable to initiate discussion, I am asking a question regarding AOS 6.x via this thread. Does AOS 6.x architecture support seamless campus roaming like in AOS 8.x architecture? I appreciate in advance for your response.
Original Message:
Sent: May 24, 2022 05:20 AM
Hi All,
Is anyone able to tell me if and when EOL or EOS for AOS 6 is?
Aruba's EOL documentation doesn't seem to cover AOS 6 anymore and i cant find the information anywhere?
Ben Casey
