AOS 6 to AOS 8 upgrade with USB
This thread has been viewed 30 times
  • 1.  AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 08:40 AM
    We have the new image file in a folder "Arubaimage" on the USB drive.  But the controller isn't mounting the USB, but it does see it.  Anyone run into this issue?
    Peter Abene
  • 2.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 08:43 AM
    Which model controller and what method are you using?
    If you are going from 6 to 8, you should use the console, so you would want to do a "write erase all" anyways because the configuration structure and the licenses are different.
  • 3.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 08:48 AM
    We are going from 6.5 to 8.6.  How else do I get the AOS 8 image file onto the controller if not using a USB drive?  I do have remote console access.
    Peter Abene
  • 4.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 08:51 AM
    The controller model is 7030
    Peter Abene
  • 5.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 08:57 AM
    I am using a USB drive with the folder Arubaimage and the image file in that folder.  We place the USB into the USB port on the controller and it's supposed to mount the USB,m read the image file and allow us to perform the upgrade using the LCD screen.
    Kind Regards,
    Peter Abene | Wireless LAN Network Engineer
    o +1 732-812-8339 • m +1 973-975-7961 peter.abene@vonage.com
    23 Main St.  • Holmdel, NJ  07733 • USA
  • 6.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 10:21 AM
    There could be a bug with that procedure.  Did you try just doing a normal upgrade?
  • 7.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 10:26 AM
    Also, ArubaImage is case sensitive, I believe.
  • 8.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 10:29 AM
    Thank you cjoseph!!
    Peter Abene
  • 9.  RE: AOS 6 to AOS 8 upgrade with USB
    Posted Jan 27, 2022 10:28 AM
    I am going to try going through the GUI, Maintenance-> Image management
