AOS 6.3 hardware requirements.
  • 1.  AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:22 PM
    I am about to upgrade 3 production controllers and I just want to make sure my hardware supports meets the 6.3 requirements.
    (cdh-aruba1-0-mc) #show mem
    Memory (Kb): total: 1540460, used: 423024, free: 1117436
    (cdh-aruba1-0-mc) #show ver
    ArubaOS (MODEL: Aruba6000-US), Version 6.1.3.9
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2013, Aruba Networks, Inc.
    Compiled on 2013-06-18 at 15:05:10 PDT (build 38704) by p4build
    ROM: System Bootstrap, Version CPBoot 1.2.0.0 (build 20527)
    Built: 2009-01-20 18:56:10
    Built by: p4build@re_client_20527
    Switch uptime is 52 days 20 hours 29 minutes 4 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor XLR 732 (revision C4) with 2016M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
    Thank you.
  • 2.  RE: AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:34 PM
    @jcX4ever wrote:
    Supervisor Card
    Thank you.
    Quite frankly, you should read the 6.3 release notes to determine if you should upgrade or not.  The memory and model are just two factors that are important.
  • 3.  RE: AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:44 PM
    I did read the pdf and I probably missed or they missed to write the minimum RAM requirement. I know, I heard before that it needs at least 1GB of RAM. I just want to make sure of this.
    The reason we are  upgrading is to be able to use some AP225.
    Anyway, I can always open a TAC.
    Thank you.
  • 4.  RE: AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:45 PM
    Thank you.
    Not trying to push you to TAC.  What MC model is that?
  • 5.  RE: AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:48 PM
    Supervisor Card slot      	: 0
    Mobility Processor        	: FPGA Rev 0x13021320
    Mobility Processor Assembly#	: 2010027B
    SC      Model#            	: Aruba6000-US
     Here's the inventory.
    Tnx
  • 6.  RE: AOS 6.3 hardware requirements.
    Posted Jan 07, 2014 06:53 PM
    Tnx
    That looks like a sup-1 or sup-2.  Those are not supported on 6.3
  • 7.  RE: AOS 6.3 hardware requirements.
    Posted Jan 08, 2014 02:07 AM
    Tnx
    It's currently on 6.1.3.9 so can't be a sup-1 or sup-2.
  • 8.  RE: AOS 6.3 hardware requirements.
    Posted Jan 08, 2014 04:46 AM
    Please open a case with support.  Show memory is not enough to know what device this is.
