last person joined: 10 hours ago
AOS 6.4 or CPPM Palo Alto Updates
  • 1.  AOS 6.4 or CPPM Palo Alto Updates
    Posted Jan 26, 2015 09:52 AM
    Now that AOS 6.4 supports direct Palo Alto User-ID integration via the XMLAPI on the PanOS:
    In an environment with both AOS 6.4 Controllers and CPPM, is there a reccomended best practice or preferred Aruba reccomendation as to which of those two sources update the User-ID info in Palo Alto?
    Thanks-
    Kevin
  • 2.  RE: AOS 6.4 or CPPM Palo Alto Updates
    Posted Jan 26, 2015 09:55 AM
    You should pick 1 source. I wouldn't recommend using two different sources.
    If you are using identity integration on your wired network, it would be
    best to use ClearPass as the Palo identity source.
  • 3.  RE: AOS 6.4 or CPPM Palo Alto Updates
    Posted Jan 26, 2015 11:22 AM
    Note that CPPM priovdes additional context over AOS to the PANW about an endpoint in the form of HIP Objects.
    And I agree with Tim, ONLY use one source as context input to the PANW.
