last person joined: 3 hours ago
AOS 6.5 - Device Name As Username
  • 1.  AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:03 AM
    Hi all, i've upgrade my controller to AOS 6.5 to test on the "Device Name As Username" as per listed in 6.5 RN.
    Unfortunately it doesn't work. Am I misunderstood the meaning?
  • 2.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:05 AM
    Did you enable it in the AAA profile?
  • 3.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:28 AM
    Hi Cappalli,
    Do you mean"Set username from dhcp option 12"
  • 4.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:32 AM
    Yes
  • 5.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:44 AM
    Hi Cappalli,
    Yes, it is enabled but not display in Webgui "User Name".
    As per checking, i found that it is displaying under "host name" in CLI "show user-table"
    Is that correct?
  • 6.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:49 AM
    It is only captured during the DHCP exchange so it may take some time to
    appear after enabling.
  • 7.  RE: AOS 6.5 - Device Name As Username
    Posted Jun 27, 2016 04:54 AM
    Noted on this. Thanks for your quick response!
