AOS 6.5.0.1 docu?
  • 1.  AOS 6.5.0.1 docu?
    Posted Oct 12, 2016 05:02 AM
    AOS 6.5.0.1 was released as GA but the docu is missing at the documentaion  GA folder.
    This still seems to be a manual process where sometimes the docu or the software isn´t published. We already saw it the other way around (docu was there, software not).
    Can we assume that a release is GA when it appears in the download section?
    Christian
  • 2.  RE: AOS 6.5.0.1 docu?
    Posted Oct 12, 2016 07:14 AM
    The documentation for 6.5.0.0 is in the folder here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/22045/Default.aspx  6.5.0.1 is just a patch release, so there would only be release notes for it in the downloads folder.  I will alert the team to the inconsistency you mentioned.
  • 3.  RE: AOS 6.5.0.1 docu?
  • 4.  RE: AOS 6.5.0.1 docu?
    Posted Oct 14, 2016 11:58 AM
    I should have explained better in my first email.
    The only thing I wanted to report ist that the 6.5.0.1 docu is not shown under the GA section.
    I think you guys are working on this.
    Christian
