AOS 8 and time-range
  • 1.  AOS 8 and time-range
    Posted Mar 17, 2022 02:06 PM
    Can someone answer one or both of the following two questions?
    Is there a way to add a custom time-range in AOS8?  not working-hours or night-hours
    How do you remove time periods from existing time-ranges?
    Example:
    Want to get rid of the struck out lines below
    (cen24-wc01) [mynode] #show time-range
    Time-Range working-hours, Periodic
    StartDay Start-time EndDay End-time Applied
    weekday 08:00 18:00 Yes
    Time-Range night-hours, Periodic
    weekday 18:01 23:59 No
    weekday 00:00 07:59 No
    daily 22:00 23:59 No
    daily 00:00 06:00 No
    Thanks in advance!
    Michael Herrighty
  • 2.  RE: AOS 8 and time-range
    MVP GURU
    Posted Mar 17, 2022 03:04 PM
    In AOS8 you would do the following to create a time range:
    time-range periodic <name of range>
    <occurrence > <start time> to <end time>
    occurrence choices:
    Daily
    Friday
    Monday
    no
    Saturday
    Sunday
    Thursday
    Tuesday
    Wednesday
    Weekday
    Weekend
    To remove times from a time-range :
    no <occurrence > <start time> to <end time>
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: AOS 8 and time-range
    Posted Apr 27, 2022 02:10 PM
    Is CLI still the only way to configure or edit this in AOS8?
    Thanks.
    Jose
  • 4.  RE: AOS 8 and time-range
    MVP GURU
    Posted Apr 27, 2022 05:12 PM
    Time ranges are still only configurable from the CLI.
    Dustin Burns
  • 5.  RE: AOS 8 and time-range
    Posted Apr 28, 2022 08:21 AM
    Thank you for confirming.
    Jose
