AOS 8 AP-provisioning Role
  • 1.  AOS 8 AP-provisioning Role
    Posted Aug 14, 2019 08:19 AM
    Hello All,
    We are running 8.4.0.4 and I am trying to setup a ap-provisioning role for a few users. I can create the account and they can login via ssh fine, however, if they go to the web GUI, they can login, but only get a blank page.
    Does anyone know if that is by design? Is that role limited to only the CLI commands? I was hoping that users would be able provising APs using the GUI.
  • 2.  RE: AOS 8 AP-provisioning Role
    Posted Aug 14, 2019 08:47 AM
    I believe that  at this time the ap-provisioning role does not work for the GUI.  This has been identified and a fix is being worked on.  I do not see an ETA for this, as of yet.  If you would care to open a TAC case, they would give you a more detailed answer, if you would like.
  • 3.  RE: AOS 8 AP-provisioning Role
    Posted Aug 15, 2019 08:50 AM
    Thanks for the prompt response. I will open a TAC case for more information.
    Thanks again!
  • 4.  RE: AOS 8 AP-provisioning Role
    Posted Aug 15, 2019 09:12 AM
    Please share your finding here. I'll need this for my team in a near future.
