  • 1.  AOS 8 bug?
    Posted May 31, 2018 08:55 AM
    Hi there!
    Now I configure a new Aruba wifi network (2 MM in cluster + 2 MC in cluster) and I'm having a strange experience. The AP shown in the picture has been turned off two days before, however, the Mobility Master tells that it's currently up and operating.
    If I enter to the controller to check this, it's shown the AP is currently down, so the MM shows incorrect information since 2 days.
    What could be the reason of this behaviour?
    MMMM
    MCMC
  • 2.  RE: AOS 8 bug?
    Posted May 31, 2018 09:14 AM
    What version of AOS8 are you running?
  • 3.  RE: AOS 8 bug?
    Posted May 31, 2018 09:19 AM
    MM: 8.2.0.0-61883
    MC: 8.3.0.0-56553
  • 4.  RE: AOS 8 bug?
    Posted May 31, 2018 09:59 AM
    @SkiP wrote:
    MM: 8.2.0.0-61883
    MC: 8.3.0.0-56553
    It is recommended that the Mobility Master is on later versions than that on the managed devices. In this case, the MD is running later firmware. The setup you have is supported, with some limitations.
    There was an issue that got resolved with 8.3.0.0 that showed the opposite problem ... the MM would report an AP as down when the MC showed the AP correctly as up.
  • 5.  RE: AOS 8 bug?
    Posted Jun 04, 2018 08:11 AM
    Today I updated MMs to 8.3.0.0, and that issue is gone.
    Thanks!
  • 6.  RE: AOS 8 bug?
    Posted May 31, 2018 09:52 AM
    I am on 8.3 and I'm experiencing the same issue. If I manually do an APMOVE command in the CLI, it seems to "jumpstart" things and show correct information for an AP that is UP... but when they are down, I've just played the waiting game.
    iann
  • 7.  RE: AOS 8 bug?
    Posted May 31, 2018 10:18 AM
    It is recommended that you have the MM with AOS higher version than the MCs , it can cause issues like this.
