AOS 8 filter API syntax
  • 1.  AOS 8 filter API syntax
    Posted Aug 06, 2018 03:16 PM
    I'm investigating the 8.3 API, and
    GET /object/ap_group
    in the WLAN section has a parameter called: "filter".  I am presuming this is a way to filter the results.  As an example, I am trying to filter based on 'profile-name'.  This seems like an efficient way to check to see if a particular group exists, and if it does how it is configured.  However, I can't find any example or documenation other than "JSON filter expression specifying the items to return" which is incredibly vague.  I have tried a few things but haven't been successful.
    Can someone point me in the right direction?
  • 2.  RE: AOS 8 filter API syntax
    Posted Aug 07, 2018 12:55 AM
    the filter syntax is described on page 28 onwards, but there are a lot of caveats around shellvars, escaping and variable formatting.
    You probably want a data filter, so something like below - note liberal use of escaping on the double quotes because I am passing in SID and MC as shellvars (cant use single quote), also need to escape the $ in the operator and also -g to stop curl processing the [ ]'s
    root@kali:/home/aruba/curl --silent --insecure -b .cookie.v8 -XGET -g -i "$MC/v1/configuration/object/ap_group?config_path=/mm&filter=[{\"ap_group.profile-name\":{\"\$eq\":[\"group-ccc\"]}}]&$SID" | grep group
        "ap_group": [
            "profile-name": "group-ccc",
    root@kali:/home/aruba/curl#
    >> here is the list unfiltered
    root@kali:/home/aruba/curl# curl --silent --insecure -b .cookie.v8 -XGET -g -i "$MC/v1/configuration/object/ap_group?config_path=/mm&$SID" | grep group                                                              "ap_group": [
            "profile-name": "group-aaa",
            "profile-name": "group-bbb",
    see if that helps, if not, paste samples of your API calls here
  • 3.  RE: AOS 8 filter API syntax
    Posted Aug 07, 2018 10:10 AM
    Page 28 of what?
  • 4.  RE: AOS 8 filter API syntax
    Posted Aug 07, 2018 11:38 PM
    @lroe wrote:
    Page 28 of what?
    the documentation, "ArubaOS 8.3.x.0 API Guide", it's on the support website.
