AOS 8 HIE SSID
  • 1.  AOS 8 HIE SSID
    Posted May 23, 2018 09:09 PM
    Hello
    SSID hide setting on AOS 8
    Where is it?
    I want to find out which menu the SSID profile is on.
  • 2.  RE: AOS 8 HIE SSID
    Posted May 23, 2018 09:35 PM
    I Check
    Configuration->System->Profiles->Wiresless LAN ->SSID
    Hide SSID option check
    thank you
  • 3.  RE: AOS 8 HIE SSID
    Posted May 24, 2018 02:57 PM
    hello,
    start by logging into your router’s admin panel. For me, this indicates going to 192.168.0.1 in my browser, but it could or might not be the identical for you. for example, most Netgear customers can attain it by going to routerlogin.net as a substitute. word that you may want a wired LAN connection to your router for the browser login to paintings.
    seek advice from your router’s guide if you aren’t certain the way to reach the admin panel. It must look some thing like this even though:
    wireless-router-admin-login
    subsequent, look in the navigation bar for the wireless section. when you have submenus, look around for some thing near wireless Settings, wi-fi alternatives, wireless > basic Settings, and many others.
    You have to be able to tweak the SSID, channel, channel mode, and channel width on the web page, but the critical aspect is to locate the choice called allow SSID Broadcast and uncheck it. relying in your router version, it can additionally be called Visibility repute, allow Hidden wireless, or just SSID Broadcast:
    wireless-router-disable-ssid-broadcast
    That’s quite a lot it. save the settings, which may or might not require your router to restart, and your router will become “undetectable” to gadgets.
    regards
    rajeshraj
    Tutuapp Android 9Apps Android Aptoide Android
  • 4.  RE: AOS 8 HIE SSID
    Posted May 24, 2018 03:12 PM
    @YOUNGLAK KO wrote:
    I Check
    thank you
    Please make sure that both of the options below are checked:
    Hide SSID: - No SSID in beacons
    Deny Broadcast Probes - No SSID returned when clients probe
  • 5.  RE: AOS 8 HIE SSID
    Posted Sep 19, 2019 02:18 AM
    Dear
  • 6.  RE: AOS 8 HIE SSID
    Posted Sep 19, 2019 02:30 AM
    Dear YOUNGLAK KO,
    I appreciated yours for advice SSID has hidden its working fine. Can you show the same way how to make profile MAC Binding I will also post the How we did in Huawei Controller we need the same thing in Aruba controller?
    As you can see below picture in Existing Huawei Controller we create Whitelist profile and apply on SSID where ever we require.
    Quick response highly appreciated.
    Thanks & Regards,
    S.A.Quadeer
