AOS 8 standalone licensing example
  • 1.  AOS 8 standalone licensing example
    Posted May 17, 2017 02:54 AM
    If I have 2 AOS 8 standalone controller and 50 AP, what are the count & type of license required?
    Answer:
    1x MC-VA-250-xx (xx is the regulartory domain)
    50x LIC-AP
    50x LIC-PEF
    50x LIC-RFProtect (if WIDS is required)
    Note: a single copy of MC-VA license is sufficient as long as we don't exceed the device count in the licensed capacity.  The above licensing bill of material also require centralized licensing is used, one VMC as licensing server while the other VMC as licensing client.
  • 2.  RE: AOS 8 standalone licensing example
    Posted May 17, 2017 06:32 AM
    Are you sure you can do centralised licensing on 2 standalone controllers?
  • 3.  RE: AOS 8 standalone licensing example
    Posted May 17, 2017 06:36 AM
    Yes, tested in lab, will post screen shots
  • 4.  RE: AOS 8 standalone licensing example
    Posted May 17, 2017 07:16 AM
    << Licensing server >>
    (VMCStandalone2) [mynode] #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status
    Configuration State Config Sync Time (sec) Config ID
    192.168.1.237 None VMCStandalone2 Building1.floor1 standalone ArubaMC-VA 8.1.0.0_59206 up
    UPDATE SUCCESSFUL 0 1
    Total Switches:1
    << Licensing client >>
    (VMCStandalone) [mynode] #show switches
    All Switches
    192.168.1.238 None VMCStandalone Building1.floor1 standalone ArubaMC-VA 8.1.0.0_59206 up
    UPDATE SUCCESSFUL 0 2
    Total Switches:1
  • 5.  RE: AOS 8 standalone licensing example
    Posted May 17, 2017 07:19 AM
    Ignore the previous lic client.jpg and use the below instead as I forgot to refresh the screen before screen shot :)
