AOS 8.0.0.0 and IAP to CAP conversion
  • 1.  AOS 8.0.0.0 and IAP to CAP conversion
    Posted Sep 15, 2016 03:39 PM
    Hi All,
    I'm having an issue converting an IAP 225 to CAP on AOS 8.0.0.0 7005 controller. Where is the table that lists minimum supported IAP version in case that is my problem?
    The user guide says "the following table describes supported IAP platforms... " but no table is shown. See attached.
    Thank you,
    N
  • 2.  RE: AOS 8.0.0.0 and IAP to CAP conversion
    Posted Sep 15, 2016 03:41 PM
    225 is supported. What are the logs on the controller showing?
  • 3.  RE: AOS 8.0.0.0 and IAP to CAP conversion
    Posted Sep 16, 2016 01:14 AM
    The logs were vague at best. I set the IAP to standalone mode, then converted to CAP. That worked.
