AOS 8.1 MD controlled by AOS 8.2 MM
  • 1.  AOS 8.1 MD controlled by AOS 8.2 MM
    Posted Jan 31, 2018 04:21 AM
    HI
    I'm in the process of migrating a customer from AOS 6.5 to 8.2 but realize that they hav 95xAP93.
    so we have 3 options
    1. obviously - replace with newer APs
    2. stay on AOS 6.5
    3. Move all 7220 controllers and MM to AOS 8.2 and use 2 x  MD7030 running AOS8.1 and retain AP93 on AOS8.1 MDs
    but will AOS 8.1 controller be managed by MM on version 8.2?
    i think I've read that this is ok - but haven't tested
  • 2.  RE: AOS 8.1 MD controlled by AOS 8.2 MM
    Posted Jan 31, 2018 06:20 AM
    Yes it is possible just need to enable multiversion.
    I haven’t test with an AP 93 I recommend that you point one of your spare/test controller to the MM and test with AP93
    Get Outlook for iOS
  • 3.  RE: AOS 8.1 MD controlled by AOS 8.2 MM
    Posted Jan 31, 2018 06:43 AM
    thanks ....
    We might favor the option of downgrading to AOS8.1 - I'll check the release notes
