AOS 8.10.0.10 and AP-325
This thread has been viewed 26 times
  • 1.  AOS 8.10.0.10 and AP-325
    Posted Apr 23, 2024 03:45 PM
    I am planning to update a 7205 controller to 8.10.0.10 and I still have some AP-325s I looked though the release notes and could not find anything in regard to updating the AP 325 with the apflash command is that not required with this AOS release?
    Thanks in advanced
    MJF
  • 2.  RE: AOS 8.10.0.10 and AP-325
    Posted Apr 23, 2024 04:03 PM
    There shouldn't be a need to use the apflash command unless you are troubleshooting with TAC and they instruct you to do so. Upgrade as you normally would.
    If you're looking to upgrade to the latest 8.10 version, 8.10.0.11 was released a few days ago.
  • 3.  RE: AOS 8.10.0.10 and AP-325
    Posted Apr 24, 2024 09:55 AM
    Thanks!
  • 4.  RE: AOS 8.10.0.10 and AP-325
    Posted Apr 24, 2024 10:10 AM
    Just to confirm the AP-325 is supported on 8.10.0.11.  The release notes does not mention that.  Page 11.
  • 5.  RE: AOS 8.10.0.10 and AP-325
    Posted Apr 24, 2024 10:13 AM
    Yes, the AP-325 is supported in 8.10 including 8.10.0.11.
  • 6.  RE: AOS 8.10.0.10 and AP-325
    Posted Apr 24, 2024 10:27 AM
    Thank you.
  • 7.  RE: AOS 8.10.0.10 and AP-325
    If you are referring to ARUBA-SA-20220922-PLVL02 :: Older AP-320 Series Access Points ArubaOS Upgrade and AP Firmware File Size Limitation (Rev-1), that procedure only has to be done once on the AP.
    Carson Hulcher, ACEX#110
