Thank you.
Original Message:
Sent: 4/24/2024 10:13:00 AM
Subject: RE: AOS 8.10.0.10 and AP-325
Yes, the AP-325 is supported in 8.10 including 8.10.0.11.
Original Message:
Sent: Apr 24, 2024 10:10 AM
Subject: AOS 8.10.0.10 and AP-325
Just to confirm the AP-325 is supported on 8.10.0.11. The release notes does not mention that. Page 11.
Original Message:
Sent: Apr 23, 2024 04:03 PM
There shouldn't be a need to use the apflash command unless you are troubleshooting with TAC and they instruct you to do so. Upgrade as you normally would.
If you're looking to upgrade to the latest 8.10 version, 8.10.0.11 was released a few days ago.
Original Message:
Sent: Apr 23, 2024 03:44 PM
I am planning to update a 7205 controller to 8.10.0.10 and I still have some AP-325s I looked though the release notes and could not find anything in regard to updating the AP 325 with the apflash command is that not required with this AOS release?
Thanks in advanced
MJF
