Not sure what the AMS domain is... is that US?
Also, this probably is easy to resolve if you show it in a live-session, and hard to solve with the limited information we have now. May be best to schedule something with your Aruba partner or Aruba support. It can be as simple as having a different regulatory domain profile applied than the one you configured, but it can be something else as well which requires a more thorough look.
Original Message:
Sent: Nov 03, 2023 12:41 PM
Subject: AOS 8.10.7 LSR GUI AP Group Creation forces UNI-3 169 & 173 Channels
Hello, thank you. I am in the AMS domain. I went to system > profiles > AP > Regular Domain, unchecked 69 & 73
Checked the same for RF management
Original Message:
Sent: Nov 03, 2023 11:42 AM
Depending on your country (and country code), channels may or may not be allowed (and indoor/outdoor is also different for most countries).
With the command 'show ap allowed-channels country-code <your country>' you can check what channels are allowed and with what bandwidths. For example in Netherlands, where I live, channels 169&173 are not allowed:
(md7005) #show ap allowed-channels country-code NLAllowed Channels for Country Code "NL" Country "Netherlands"------------------------------------------------------------PHY Type Allowed Channels-------- ----------------2.4GHz (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 135GHz (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 1656GHz (LP indoor) 1 5 9 13 17 21 25 29 33 37 41 45 49 53 57 61 65 69 73 77 81 85 89 932.4GHz (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 135GHz (outdoor) 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 1652.4GHz 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-135GHz 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-1616GHz 40MHz (LP indoor) 1-5 9-13 17-21 25-29 33-37 41-45 49-53 57-61 65-69 73-77 81-85 89-932.4GHz 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-135GHz 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-136 149-153 157-1615GHz 80MHz (indoor) 36-48 52-64 100-112 116-128 149-1615GHz 80MHz (outdoor) 100-112 116-128 149-1616GHz 80MHz (LP indoor) 1-13 17-29 33-45 49-61 65-77 81-935GHz 160MHz (indoor) 36-64 100-1285GHz 160MHz (outdoor) 100-1286GHz 160MHz (LP indoor) 1-29 33-61 65-935GHz (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140support zero-wait-dfs Yes
Original Message:
Sent: Nov 02, 2023 03:42 PM
Hello, I am running on 8.10.7 LSR on Mobility. If I try to create a new group, I am forced to enable 169 & 173 at 20MHz. The other stable AP groups enable 36 - 165 at 20MHz. If I try to go back and uncheck 69 & 73 it won't apply.
I have the AOS10 training, I didn't see anywhere that reads 169 & 173 are recommended and valid channels. Am I missing something? I apparently didn't get the memo if 169 & 173 are valid and should be default at 20 MHz.
