AOS 8.12.0 Release Notes inconsistent
This thread has been viewed 24 times
  • 1.  AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 07:35 AM
    The release notes have dropped the AP335 and 345 from the supported devices list but there is a Resolved Issue AOS-239341 which says that it fixes an AP345 issue with high utilisation.  I also can't see anything in the release notes or on the download site that says whether this release is an SSR or LSR.
    Obviously I won't be updating the production network for some time, but can anyone clarify these points?
  • 2.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 08:54 AM
    AOS-239341 was fixed and released in multiple versions including 8.12.0.0. For example, 8.10.0.6 (Resolved Issues in ArubaOS 8.10.0.6).
    8.12 is a SSR.
  • 3.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 11:25 AM
    Thanks, that explains it.  So the 335/345 are dropped in this release even though they are still supported to October 2026?
  • 4.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 11:28 AM
    335/345 were deprecated in 8.11 onwards. https://www.arubanetworks.com/techdocs/ArubaOS_8.11.0_Web_Help/Content/arubaos-solutions/whats_new.htm
  • 5.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 12:02 PM
    ... and correct about the dropped support in releases above 8.10. You can still run the AOS 8.10 release (supported till Apr 13, 2027) on those APs till the end of support date of the AP.
  • 6.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 12:38 PM
    It's a case of weighing up the benefit of bugfixes against the cost of replacing equipment.  8.12 had a couple of fixes to minor issues I had raised so was hoping to be able to go up to it but if it's only an SSR and I have to replace 61 APs, I will probably just live with the problems a bit longer.
    Thank you both for clear and helpful responses.
  • 7.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 12:41 PM
    Would the bug fixes not be added to 8.10 since its an LSR?
  • 8.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 12:47 PM
    8.10 will continue to get bugfixes.
  • 9.  RE: AOS 8.12.0 Release Notes inconsistent
    Posted Mar 11, 2024 12:58 PM
    Ah!  That's good news.  TAC told me my fixes would be in 8.12 but I have just checked and they are in 8.10.10 as well.
