AOS 8.2 upgrade - 1 controller lost after upgrade
  • 1.  AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:05 PM
    HI
    just did an upgrade to AOS8.2 and when controllers rebooted - the 2. controller never connected to Mobility Master. But it have retained its local configuration (ports, ip addresses) but shows as a master controller rather then connected to Mobility Master
    why ? but should I do a factory reset or ??
  • 2.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:14 PM
    Can you check what AOS and partition is currently using ?
  • 3.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:24 PM
    (WLAN) [mynode] # show image version ---------------------------------- Partition : 0:0 (/dev/usb/flash1) Software Version : ArubaOS 8.1.0.1 (Digitally Signed SHA1/SHA256 - Production Build) Build number : 59688 Label : 59688 Built on : Thu May 18 21:34:48 UTC 2017 ---------------------------------- Partition : 0:1 (/dev/usb/flash2) **Default boot** Software Version : ArubaOS 8.2.0.0 (Digitally Signed SHA1/SHA256 - Production Build) Build number : 61883 Label : 61883 Built on : Fri Oct 13 22:38:25 PDT 2017
  • 4.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:26 PM
    upgrade from AOS 8.1.0.1
    Looking at the upgrade notes I can't find any good gotchas that might lead to this either
  • 5.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:36 PM
    Please open a TAC case and preserve the logs (tar logs tech support from both MM and all MDs in their current state). From here, the fastest fix is to likely either roll back to 8.1.0. from a backup (that you hopefully took before upgrading), or you can wr erase all the MDs and re-point them back to the MM.
  • 6.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 03:37 PM
    I have backups. And are on the phone with TAC as well.
    Thanks - will keep you posted :-)
  • 7.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Oct 19, 2017 05:50 PM
    write erase all
    reconfigure
    all good
  • 8.  RE: AOS 8.2 upgrade - 1 controller lost after upgrade
    Posted Nov 09, 2017 08:50 AM
    should probably add some more information here, since time was rather limited when posting this originally.
    what saved us is that the Mobility Master was up and running.
    So for each MD we did this:
    1. write erase all
    2. full-setup and use same IP-address and network settings as originally used/entered into mobility master.
    3. reboot MD after network was configured and the rest of the configuration were once again pushed from MM
    neat :)
