AOS 8.2.1 Cluster VIP
  • 1.  AOS 8.2.1 Cluster VIP
    Posted Apr 04, 2018 09:26 PM
    I have setup a simple 2-node cluster.
    Virtual Router 220:
        Description
        Admin State UP, VR State MASTER
        IP Address 192.168.1.248, MAC Address 00:00:5e:00:01:dc, vlan 1
        Priority 255, Advertisement 1 sec, Preemption Enable Delay 0
        Auth type NONE ********
        tracking is not enabled
    Virtual Router 221:
        Description
        Admin State UP, VR State BACKUP
        IP Address 192.168.1.247, MAC Address 00:00:5e:00:01:dd, vlan 1
        Priority 235, Advertisement 1 sec, Preemption Enable Delay 0
    AP/Client load balancing appears to be working fine. However, I would like to setup a cluster VIP for one single IP for new AP discovery. I have read that you can set this up using VRT under Redundancy. However, when I try to use an IP that is not on any interface I get an error saying I cannot use that IP.
    Am I going about this the wrong way?
    Thanks in advance!
  • 2.  RE: AOS 8.2.1 Cluster VIP
    Posted Apr 04, 2018 09:37 PM
    Need to configure directly under each MD
  • 3.  RE: AOS 8.2.1 Cluster VIP
    Posted Apr 05, 2018 04:48 PM
    Setup VRRP configuration for AP provisioning on each md separate from cluster settings
    #AirheadsMobile
  • 4.  RE: AOS 8.2.1 Cluster VIP
    Posted Jun 06, 2018 06:30 PM
    Ok, I find this confusing. In the lab directions for the SWDI course, it specifically says to do this in the cluster settings. Did this change between 8.1 and 8.2?
  • 5.  RE: AOS 8.2.1 Cluster VIP
    Posted Jun 06, 2018 06:37 PM
    Yup. Also, since I've been going through the Aruba 8 press book I see it is riddled with UI differences compared to today.
    However, to add a VIP for AP discovery, it must be configured directly on each MD (at least in 8.2+)
  • 6.  RE: AOS 8.2.1 Cluster VIP
    Posted Jun 06, 2018 06:40 PM
    So as a regular VRT under redudancy and no configuration at all under the cluster profile correct?
    Thanks!
  • 7.  RE: AOS 8.2.1 Cluster VIP
    Posted Jun 06, 2018 06:45 PM
    If you're cluster is already stood up.
    Navigate to the specific device and configure a VRT on each one to use the same IP (and settings)
