Good Afternoon,
i would like some help with the operation of this new AOS. I have a hyper-v server with two HD and 8 GB of RAM. I loaded P0 and then it stops..The attachements will have configuration of Hyper-V server and the VM. I have restarted system and each time it stops at this point.
Yes, very familiar with this document. I have followed the directions like a bible. Yet the VM does not go any further, i checked the version of HV and it HV2012.
Since I have only one NIC for the VM would that cause an issue. In the instruction it is asking for a removal of NEtwork Adapter then making a Etherchannel in the next caption? Could that be the issue....
You need 2 network adapters, but not etherchannel.
Double check the Hardware Acceleration and Advanced Features for these Network Adapters
These are my working Hyper-V MM:
Good Morning,
I saw the last post, so I move the VM to another server where I could finish testing the new AOS. So in the documents it tells of going into PowerShell and creating a port-channel. Is that action still needed if on the GUI I give the server 2 NIC's?
These are base on my personal experience, probably not the best pratice:
