AOS 8.4.0.2: DNS Server not shown in GUI
  • 1.  AOS 8.4.0.2: DNS Server not shown in GUI
    Posted May 20, 2019 02:30 PM
    Hello!
    I have a problem in a new AOS 8.4.0.2 MM/MC deployment.
    Under System -> General -> Domain Name System, the konfigured domain servers are not displayed.
    It does not matter where we configure the DNS servers, on GUI (on Mobility Master level or on the MM itself, the same on MC and it's layers above) or at CLI.
    If we insert the DNS servers, and click Apply - they are showing up for a part of a second and desappear again.
    The interesting thing is, that the "Deploy Changes" button gets active, and we can deploy the DNS servers to the startup config.
    On the CLI we can find the servers with command #show ip domain-name.
    DNS discovery works without issues.
    I can't find a known issue entry to this in any 8.4.x release note.
    Does anybody saw this phänomen bevore?
  • 2.  RE: AOS 8.4.0.2: DNS Server not shown in GUI
    Posted May 20, 2019 03:16 PM
    Yes, I've also seen this problem, and this is reported as a bug. But maybe you can also report this
  • 3.  RE: AOS 8.4.0.2: DNS Server not shown in GUI
    Posted May 20, 2019 03:24 PM
    Hi!
    With 8.4.x or also lower?
  • 4.  RE: AOS 8.4.0.2: DNS Server not shown in GUI
    Posted May 20, 2019 03:27 PM
    With 8.4. I searched in my history but can't find the bug ID
  • 5.  RE: AOS 8.4.0.2: DNS Server not shown in GUI
    Posted May 20, 2019 03:33 PM
    Ok, I will open a TAC case on this.
    Meybe I get the BUG ID from them.
    Thank you for your response!
