AOs 8.6 - Active Standby MCs with MM
  • 1.  AOs 8.6 - Active Standby MCs with MM
    Posted Oct 15, 2020 06:03 PM
    Hello.
    I would like to know if it's possible to have active standby in AOS 8.6 using Mobility Master. Due to a project design, I can't use clustering to balance the clients/aps and have both in use.
    I need to setup one MC as active and other MC as standby in case of failure of the first.
    I have no problem with the the time of failover, just need to let it automatically.
    It's possible?
  • 2.  RE: AOs 8.6 - Active Standby MCs with MM
    Posted Oct 15, 2020 06:07 PM
    You can still setup LMS-IP and backup LMS-IP two two controllers who are not in a cluster.
  • 3.  RE: AOs 8.6 - Active Standby MCs with MM
    Posted Oct 15, 2020 06:10 PM
    Thank you Joseph... even if the both controllers are in the same L2 of the APs, the LMS will work?
  • 4.  RE: AOs 8.6 - Active Standby MCs with MM
    Posted Oct 15, 2020 06:21 PM
    No matter what controller the APs discover first, the APs will switch to the LMS and then fail over to the Backup LMS.
