AOS 8.x - How to create a WLAN from scratch
  • 1.  AOS 8.x - How to create a WLAN from scratch
    Posted May 08, 2018 10:05 AM
    This would be helpful for anyone new to AOS 8
    We will be creating a WPA2 802.1x SSID for the below Network Setup, leveraging Clustering and L2 Mobility Master Redundancy based on ArubaOS Release 8.3.0.0MyNetwork1.jpg
    Deploying the Virtual Mobility Master with VMWare
    Download the "ArubaOS_MM_8.3.0.0_64659.ova", from http://support.arubanetworks.com/
    Open your vSphere Client and "Goto File -> Deploy OVF Template" and go through the wizard to get ArubaOS_MM_8.3.0.0_64659.ova deployed.
    MM consumes 3 vCPU, 6GB RAM and 16 GB Storage.
    Power ON the deployed Virtual Machine and MM by default boots from Partition 0
    Fill in the start-up questions, below is how it looks. Once completed Mobility Master(MM1) will be UP.MM_Bringup1.jpg
     Use the above process and bring the other Mobility Master (MM2) as well.
    Licensing the Mobility Master
    Note: Just like licenses for Hardware Controllers are tied to Serial Number, the licenses for Virtual Machines are tied to "License Passphrase", which can be found at
    Mobility Master -> Configuration -> System -> Licensing -> Mobility Master Licenses -> Click on + Signpassphrase.jpg
    Your Virtual Machine licenses should be activated against "License Passphrase"
    Once activated enter the license at
    Mobility Master -> Configuration -> System -> Licensing -> Mobility Master Licenses -> Click on + Sign -> Paste the License.
    Configuring L2 Mobility Master Redundancy
    It involves two parts, one is configuring the VRRP and other is configuring the Master Redundancy.
    Note: If you are deploying 2 MM on the same Virtual Machine, for the VRRP to work between them, please ensure "Promiscuous Mode: Accept" in that Virtual Machine Port Group.
    Configuration -> Networking -> vSwitch0 -> Properties -> Select the Port Group -> And Edit its Properties.Promiscuous Mode.jpg
    Configuring VRRP:
    Goto Actual Mobility Master (/mm/mynode) of MM1 and MM2
    Navigate to Configuration -> Services -> Redundancy -> Virtual Router Table -> Click on the + sign
    Configure the following values.
    MM1
    MM2
    ID
    50
    50
    IP Version
    V4
    V4
    Authentication Password:
    aruba123
    aruba123
    IP Address:
    192.168.26.2
    192.168.26.2
    Priority:
    200
    150
    Admin State:
    UP
    UP
    VLAN:
    26
    26
    Master Redundancy
    Navigate to, Configuration -> Services -> Redundancy -> Master Redundancy
    MM1
    MM2
    Master VRRP:
    50
    50
    IP address of peer:
    192.168.26.3
    192.168.26.1
    Authentication:
    IPSec Key
    IPSec Key
    IPSec Key:
    aruba123
    aruba123
    Enable Database Synchronization:
    Goto the MM (/mm) group above MM1 and MM2
    Navigate to Configuration -> Services -> Redundancy -> Master Redundancy ->
    Sync Period: 60 minutes
    Use “database-synchronize” command on Mobility Master, to force database synchronization on demand.
    Final Screenshot
     Verification Commands:
    show vrrp
    show database synchronize
    show switches
    Adding Mobility Controller to MM
    Ensure the Mobility Controller (eg: 7010 Controller, 7005 Controller) has ArubaOS_8.3.0.0 image in one of the boot partitions and boot it from that partition.
    One the Mobility Controller comes up, Fill in the start-up questions. Following is the screenshot.MC_Bringup.png
    Authorize the Mobility Controller in the Mobility Master.
    Navigate to Mobility Master -> Configuration -> Controllers -> Local Controller IPSec KeysAuthorizing the MCs.jpg
     Add the Controller into the Group (MAC Address can be got by typing "show inventory" on the Mobility controller)
    The Configuration Node Hierarchy and Inheritance
    This can be viewed by using the following CLI command.Config-Node-Hierachy.jpg
    Creating a Cluster among the Mobility Controllers:
    Creating a Cluster:
    Navigate to Managed Network -> CampusA -> Configurations -> Services -> Clusters -> Click on + sign
    On the Controllers Box, add both the Controllers.
    7010 Mobility Controller
    7005 Mobility Controller
    IP Version:
    V4
     v4
    IP Address:
    192.168.17.177
    192.168.17.17
    Priority:
    200
    200
    Now Goto the Actual Mobility Controllers 7005 and 7010 (eg: /md/Campus-A/00:0b:86:be:dc:d0 )
    Navigate to -> Configuration -> Services -> Cluster -> Cluster Profile
    Cluster group-membership: Campus-A-Cluster
    Exclude VLAN: 1
    If all VLANs in Mobility Controller 1 (7010) can see all VLAN in Mobility Controller 2 (7005), then the Cluster is L2 Connected
    If they can't see all the VLANs, but reachable to each other, then cluster is L3 Connected.
    Can be verified at, Managed Networks -> Dashboard -> Cluster
    Provisioning APs:
    For this “Campus-A” Group, I am going to "Enable auto cert provisioning"
    Goto “Campus-A” Group -> Configuration -> System -> CPSec -> Control Plane Security -> Enable "Auto Cert Provisioning"
    Set up VRRP between Mobility Controllers (7005 and 7010) in the cluster.
    Vrrp id
    60
    60
     IP address
    192.168.17.100
    192.168.17.100
    authentication
    aruba123
    aruba123
     priority
    200
    150
    Admin State
    UP
    UP
    VLAN
    17
    17
    AP discovers the Controller using the following options.
    • Static
    • DHCP
      • option 60 text ArubaAP
      • option 43 text 192.168.17.100
    • DNS
      • By resolving "aruba-master" to 192.168.17.100
    • ADP
    Once the AP comes UP, it will fall into the default Group.
    Verify whether the APs have come UP using the following command.AP database long.jpg
    Creating a WPA2 802.1x SSID
    Navigate to Campus-A -> Configuration -> AP Groups -> Click on + sign -> Add the Group "Global-AP-Group"
    Goto Campus-A -> Configuration -> WLANs -> Click on + sign -> Run through the “New WLAN” Wizard
     We have used the Named VLAN which was created at
    Configuration -> Interfaces -> VLANs
    VLAN name: EmployeeVLAN
    VLAN ID: 17
    This VLAN ID can be overwritten by the Mobility Controllers under the “Campus-A” Group
    Security Tab:
    Select "Enterprise" level security and add the Clearpass Server.
    Once the WLAN is configured, Move the APs into the AP-Group you configured.
    Goto Campus-A -> Configuration -> Access Points -> CampusAPs -> Select the APs -> Click on Provision and move it to the AP-Group (Global-AP-Group) you configured.Provision.jpg
     Connect your clients to the SSID and verify it in the Dashboard.Clientdot1xConnected.jpg
     Hope you find this useful. Please post your feedback !
    Kapildev Erampu
