Developer
AOS 8.x IaC
  • 1.  AOS 8.x IaC
    Posted Dec 10, 2020 06:02 PM
    Given the hierarchical nature of the Mobility Master/Conductor, how would you recommend doing configuration management via a ci/cd pipeline? Since different configuration segments would be homed in different level of the hierarchy, I am having trouble wrapping my brain around it as it compares to a switch configuration (e.g. ArubaOS-CX or another vendor), where everything is all in one hierarchy level. Normally, I would just update the data model/host vars file, and the playbook would generate the config updates from a jinja2 template, etc.
    Thanks in advance.
    Evan Fisher
