Developer
AOS-CX 10.04 REST and NAE Guides published!
  • 1.  AOS-CX 10.04 REST and NAE Guides published!
    Posted Nov 04, 2019 06:53 PM
    Hi Everyone!
    With the announcement of the launch of 10.04, we at Aruba has also published new REST guides for AOS-CX on the HPE Support Center.  Note that there is now a version upgrade to the REST calls, so there is now a REST guide for both the v1 REST API and the v10.04 REST API, which is linked below.
    These guides are created for the 6300, 6400, 8320, 8325, and 8400 models.
    AOS-CX 10.04 REST v1 API Guide: https://support.hpe.com/hpsc/doc/public/display?docId=a00091709en_us
    AOS-CX 10.04 REST v10.04 API Guide: https://support.hpe.com/hpsc/doc/public/display?docId=a00091710en_us
    In addition, we have updated the Network Analytics Engine Guide for 10.04.  Check it out in the link below!
    AOS-CX 10.04 Network Analytics Engine Guide:  https://support.hpe.com/hpsc/doc/public/display?docId=a00091704en_us
    Each of these guides are in PDF format, but we intend to release the HTML versions of the guide very soon.
  • 2.  RE: AOS-CX 10.04 REST and NAE Guides published!
    MVP GURU
    Posted Nov 04, 2019 11:12 PM
    Thanks Alvin for info
    What the plan ? v1 will be remove on future release ?
  • 3.  RE: AOS-CX 10.04 REST and NAE Guides published!
    Posted Nov 05, 2019 12:55 PM
    Hello!
    We will maintain API backwards compatibility for a sufficient period of time, but we intend on focusing on the newer REST versions as our technology develops.
  • 4.  RE: AOS-CX 10.04 REST and NAE Guides published!
    Posted Nov 13, 2019 05:18 AM
    Hi Alvin,
    Thanks for the info.
    Is there also  a "REST API and JSON Schema" documentation like the one provided for ArubaOS-Switch ?
    Best,
    Guillermo
  • 5.  RE: AOS-CX 10.04 REST and NAE Guides published!
    MVP GURU
    Posted Nov 13, 2019 05:33 AM
    @guillote wrote:
    Hi Alvin,
    Best,
    Guillermo
    There is a Swagger directly on the switch !
