Wired
last person joined: 11 hours ago
AOS-CX 10.7: Port-access VLAN Group
This thread has been viewed 29 times
  • 1.  AOS-CX 10.7: Port-access VLAN Group
    Posted Apr 21, 2021 09:52 AM
    AOS-CX 10.7 Port-access VLAN group (VLAN pool)
    VLAN Grouping feature provides distribution of clients across the VLANs in the box to reduce the broadcast domain of secure clients. This feature enables allocating a VLAN from a preconfigured list of pool, thus reducing the need for administrators to load balance the network.
    VLAN group leverages the existing standard attribute Tunnel-Group-Private-ID(81).
    This standard attribute is overloaded to be interpreted as VLAN group name, if the VLAN name doesn't exist on the switch with that name.
    Required Configuration on AOS-CX:
    Required Configuration on Clearpass/AAA server:
    Verification and validation
    Below is output contains one dot1x and one mac-auth client, associated vlan pool will distribute vlan upon successful authentication.
    Required Packet Capture for dot1x client
    1. Access-request
    2. Access-challenge
    3. Access-request
    4. Access-Accept
    Packet Capture for mac-auth client
    1. Access-request
    2. Access-accept
    Please feel free to download AOS-CX 10.7 image and give a try.
    https://asp.arubanetworks.com/downloads;products=Aruba%20Switches
    Good day!
    Yash NN
