Wired
AOS-CX 10.7: SNMP Write Support
  • 1.  AOS-CX 10.7: SNMP Write Support
    Posted Apr 21, 2021 09:41 AM
    Finally, most wanted and requested feature is supported on AOS-CX platforms, i.e., SNMP Write Infra Support.
    With 10.7 only following snmpset operation are supported
    1. PoE Enable, Disable, Power Cycle
    No Power-over-ethernet – Disable PoE
    No Power-over-ethernet – Enable PoE
    Per port Power Cycle
    2. Switch: hostname, system-contact, location
    Switch hostname
    Switch system-contact
    Switch system-location
    Please feel free to download AOS-CX 10.7 image to give a try!
    https://asp.arubanetworks.com/downloads;products=Aruba%20Switches
    Good day!
    Yash NN
