Wired Intelligent Edge
AOS-CX ACL commands (COUNT/LOG) ???
  • 1.  AOS-CX ACL commands (COUNT/LOG) ???
    Posted Jun 09, 2020 05:44 AM
    Re: AOS-CX ACL commands (COUNT/LOG)
    I have not found a global method to add/remove COUNT to every ACE in mass.
    A method to automatically add/remove a "LOG COUNT" parameter to each ACE by using an ACL global COMMAND.
    If there is not a method, there should be.
    Something like (similar to the resequencing command paramter):
    access-list ip FILTER_TO_HOST_B COUNT deny
    and
    access-list ip FILTER_TO_HOST_B LOG COUNT deny
    and
    access-list ip FILTER_TO_HOST_B LOG COUNT any
    Yes, I understand you can presently only LOG DENY ACE's but the OS could be smart enough to add Logs/Counts to any ACE that is supported when the ACL COUNT/LOG command is applied.
    #8320
