Wired Intelligent Edge
AOS-CX allow-unsafe-updates via REST API?
This thread has been viewed 45 times
  • 1.  AOS-CX allow-unsafe-updates via REST API?
    Posted Dec 13, 2023 01:51 PM
    Hello everyone,
    is it possible to allow unsafe updates via API?
    Couldn't find anything in the documentation so far.
  • 2.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Feb 16, 2024 05:33 AM
    Doesn't seem possible right now. I asked the same question here:
    https://community.arubanetworks.com/discussion/is-it-possible-to-allow-unsafe-updates-via-api-or-ansible
  • 3.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Feb 17, 2024 05:54 AM
    I have a Expect script which may be used during staging.
    As you can see it is a reboot after enable the allow-unsafe-updates. I use it as part of ZTP so new firmware is automaticly downloaded and I need to reboot with allow-unsafe-updates if needed.
    If you want to use this as part of a upgrade of switches in production, remove the reboot. And perform the firmware upgrade using your standard tools.
    #!/usr/bin/expect
    #Usage  allow-unsafe-upgrade.expect <host> <ssh user> <ssh password>
    set timeout 60
    spawn ssh [lindex $argv 1]@[lindex $argv 0]
    expect "yes/no" {
            send "yes\r"
            expect "*?assword" { send "[lindex $argv 2]\r" }
            } "*?assword" { send "[lindex $argv 2]\r" }
    expect "# " { send "configure\r" }
    expect "fig)# " { send "allow-unsafe-updates 20\r" }
    expect "(y/n)? " { send "y\r" }
    expect "fig)# " { send "boot system\r" }
    expect "(y/n)? " {
            send "y\r"
            } "(y/n)? " { send "y\r" }
    expect eof
    Arne Opdal
  • 4.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Feb 19, 2024 03:23 AM
    Thanks alot :)
  • 5.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Feb 23, 2024 08:42 AM
    Thanks Arne for the script, that looks like a good workaround.
    But my understanding is that the AOS-CX operating system is a fully API featured one, isn't it?
    Then it should also be possible to implement this function on the API.
    @jonlar, @ArneO: Have you already contacted TAC support about this?
    Otherwise I will create a request for this.
  • 6.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Feb 28, 2024 09:04 AM
    I know other stuff that doesn't work with the API as well, so they probably have a feature backlog with the API.
    I have not contacted TAC.
  • 7.  RE: AOS-CX allow-unsafe-updates via REST API?
    Posted Mar 18, 2024 02:47 AM
    I have opened a TAC case.
    There it could be determined that the function is not implemented.
    I was advised to create a feature request at https://innovate.arubanetworks.com/, which I did.
    The request can be found at https://innovate.arubanetworks.com/ideas/SWITCH-I-916
    Upvotes are appreciated :)
