Wired Intelligent Edge
AOS-CX: boot / reload / restart / disconnect TIMER ?
This thread has been viewed 49 times
  • 1.  AOS-CX: boot / reload / restart / disconnect TIMER ?
    Posted Oct 18, 2019 11:21 AM
    I perform remote AOS-CX maintenance on a regular basis.
    There are times my revised/new settings may cause my remote discussion to be disconnected.  The LARGE changes at time then do not allow me to reconnect to the AOS-CX switch.  I would like a system similar to the AOS-switch (hpe provision) where one can time a reload.  If one sets the reload timer to reload, and the time code is met, the switch is rebooted w/ saving the config and then the new settings are dropped.
    Is this type of "auto boot" available on AOS-CX???  Have not found in aos-cx manuals or on airheads.
    -N
    # Thanks # Gracias # Merci # ありがとう # Danke # Spasiba # 감사합니다 # Toda # Cheers # Dhanyawaad # Ahsante # Xièxiè # shukran #
  • 2.  RE: AOS-CX: boot / reload / restart / disconnect TIMER ?
    MVP GURU
    Posted Oct 19, 2019 06:13 AM
    Do you have look checkpoint ?
    and also do you have look the tool NetEdit ?
  • 3.  RE: AOS-CX: boot / reload / restart / disconnect TIMER ?
    Posted Oct 19, 2019 10:15 AM
    Thanks alagoutee !!!   (and a shout-out to parnassus for similar help in a related POST).
    From 8320 (10.03) CLI DOC:
    Syntax
    checkpoint auto <TIME-LAPSE-INTERVAL>
    Description
    Starts the auto checkpoint mode. In auto checkpoint mode, the system temporarily saves the runtime
    configuration as a checkpoint only for the specified time lapse interval.
    Usage
    To save the runtime checkpoint permanently, run the checkpoint auto confirm command during the
    time lapse value set by the checkpoint auto <TIME-LAPSE-INTERVAL> command. The filename for the
    saved checkpoint has the AUTO<YYYYMMDDHHMMSS> syntax. If the checkpoint auto confirm command is
    not entered during the specified time lapse interval, the previous runtime configuration is restored.
    *****BEGIN: ACTUAL TESTED CLI CHECKPOINT EXAMPLE BELOW *****
                        (minimally edited for POST presentation clarity)
    HPE-AOSCX8320-DO-NOT-REVISE# check auto 2
    Auto checkpoint mode expires in 2 minute(s)
    WARNING Please "checkpoint auto confirm" within 2 minutes
    HPE-AOSCX8320-DO-NOT-REVISE# conf
    HPE-AOSCX8320-DO-NOT-REVISE(config)# hostname what-me-worry
    what-me-worry(config)# exit
    WARNING: Restoring configuration. Do NOT add any new configuration.
    Configuration changes will take time to process, please be patient.
    Restoration successful
    *****END: ACTUAL TESTED CLI CHECKPOINT EXAMPLE ABOVE *****
