Wired Intelligent Edge
AOS-CX equivalent to "controlled-direction" in aaa port-access
This thread has been viewed 47 times
  • 1.  AOS-CX equivalent to "controlled-direction" in aaa port-access
    Posted Apr 27, 2022 03:08 PM
    Does the CX switch line have a configuration option for limiting only incoming traffic on a 802.1X-aware port in a pre-auth state?  Use case is active ping sweeps for devices in the pre-auth VLAN that do not send an Ethernet frame otherwise, so they can pass MAB (and also in Wake-on-LAN scenarios?)
    Daniel Waites
  • 2.  RE: AOS-CX equivalent to "controlled-direction" in aaa port-access
    Posted Apr 28, 2022 03:15 AM
    Hi Daniel
    there is no exact equivalent on ArubaOS-CX for this command. However, have a look at "port-access allow-flood-traffic" and "aaa authentication port-access allow-lldp-bpdu" commands, which could do the job in your case.
    https://www.arubanetworks.com/techdocs/AOS-CX/10.07/PDF/5200-7836.pdf
    Best regards,
    Thomas
    Thomas Siegenthaler
  • 3.  RE: AOS-CX equivalent to "controlled-direction" in aaa port-access
    Posted Apr 28, 2022 03:20 AM
    The following command should provide similar effect. It allows outgoing BUM traffic on an unauthenticated port.
    port-access allow-flood-traffic {enable | disable}
    Description
    Enables or disables transmission of flood traffic, such as broadcast, multicast, and unknown unicast
    messages through a security enabled port on which no client has been authenticated.
    By default, transmission of flood traffic is disabled.
    Usage
    This command can be used to allow Wake-on-LAN packets on security enabled ports, before a client is
    authenticated
    Examples
    Enabling flood traffic on a port:
    switch(config-if)# port-access allow-flood-traffic enable
    Emil Gogushev
  • 4.  RE: AOS-CX equivalent to "controlled-direction" in aaa port-access
    Posted Apr 13, 2023 08:56 AM
    Thank you so much.
    I will try it out and hope for the best :)
    Best regards,
    Alon Haber
