I have CX 10.13 running on EVENG on Proxmox.
On Proxmox, VMs do not support nested virtualization and you need to enable it.
1 - First, your Promox server need to have nested virtualization enabled, you can confirm it with the command below (the response has to be Y):
cat /sys/module/kvm_intel/parameters/nested
Y
2- The EVENG VM it self to support nested virtualization:
- Shutdown the EVENG VM,
- Go the CPU setting of the EVENG VM and make sure Type is set to host and not something else (just like the Screenshot below)
- Start your EVENG VM, then you should be fine and start building your labs.
Good Luck
Achraf Harkati
Original Message:
Sent: Nov 27, 2023 12:31 PM
Subject: AOS-CX not starting on Eve-NG with Proxmox
I'm desperately trying to start a virtual lab for AOS-CX on EveNG.
After all my debugging, I can't start the AOS-CX : the devices either doesn't start at all, or it starts but stays on a black screen when opening console.
I have a Lubuntu VM with EveNG 5.0.1-13 installed on it. This VM is hosted on a Proxmox Server.
The VM has 64Gb of RAM, CPU is set to 12Vcores with direct CPU access (host mode)
I have followed the EveNG tutorial to export ova to qcow2 and then place it in /opt/unetlab/addons/qemu/[arubacxversion]
The file is exactly named virtioa.qcow2
I have tried those versions : arubacx10.05, .06, 07, .12, .13
None of them seem to boot up properly, I have no relevant error log on every log file that eveNG has to offer.
What can I do?
