Wired Intelligent Edge
AOS-CX Pre-auth profiling ACL question
  • 1.  AOS-CX Pre-auth profiling ACL question
    Posted Sep 13, 2022 06:48 PM
    - I'm creating a 'profiling' role to be used as a wired pre-auth role on an AOS-CX switch.
    - The role will only allow DHCP for the purpose of profiling against ClearPass.
    - I would like to use an existing Guest VLAN for this
    My question is, is there a way to prevent DHCP responses from reaching the client and an IP address being assigned?
    I suppose the real question is, do port-access policies apply to inbound or both inbound/outbound traffic as well?
    class ip ANY
        10 match any any any
    class ip DHCP
        10 match udp any any eq 67
    port-access policy Profiling_ACL
        10 class ip DHCP
        20 class ip ANY action drop
  • 2.  RE: AOS-CX Pre-auth profiling ACL question
    Posted Sep 14, 2022 05:53 AM
    As far as I know the role is applied inbound only (from client to the switch/network).
    Have you considered to create a profiling VLAN, which can have a dummy IP and ip-helpers to just the ClearPass server?
    Another option is to just use the guest VLAN, and add a captive portal redirect to ClearPass, with the benefit that you might get a browser User-Agent as well from the client that connected for additional profiling. And unless the client is profiled, it allows the end-user to login as wired guest or use an Operator Profile to do device registration. I tend to use the guest-login role/VLAN for profiling because the guest VLAN is open to untrusted users in most cases, so perfect for profiling.
  • 3.  RE: AOS-CX Pre-auth profiling ACL question
    Posted Sep 14, 2022 04:27 PM
    Thanks Herman!
    Yes, I've used a profiling VLAN in the past with dummy IP and only helpers pointing to ClearPass.
    I was just trying to minimize the number of VLANs deployed this time :)
    The reason I'd prefer not to use captive portal in this environment is MAB will be used for devices such as printers that don't behave well to a VLAN change after they've already received an IP address.
  • 4.  RE: AOS-CX Pre-auth profiling ACL question
    Posted Sep 15, 2022 07:52 AM
    That is the reason why you should role/dACLs instead of change VLANs. That dummy VLAN only has local significance, so you don't need to distribute it across your switches, but if the design doesn't match a separate dummy VLAN for profiling, that will not work.
    BTW, on wired, I found that when you do a port bounce (long enough), most devices will re-do a DHCP. If you have to do VLAN changes, make sure you combine it with a port-bouce.
