that is interesting, i think it is time to get in touch with Aruba support to get to the bottom of it.
Original Message:
Sent: Feb 13, 2024 04:07 AM
Subject: AOS-CX QoS for audio streams
I've left only:
policy QOS_TEST
10 class ip LIVESTREAM action pcp 5
20 class ip MEDIUM action pcp 3
40 class ip BIURO action dscp CS0
and the result is the same.
BTW: on the 8325 it is possible to apply a policy to the inbound traffic while on 6300 in both directions. It looks like the policy is lost when packet is routed. the example I mentioned is for a switched traffic.
-- tommyd
Original Message:
Sent: Feb 12, 2024 09:53 PM
your config looks good. to narrow it down I suggest to only change the PCP (remove all the other actions) and see if that gets changed correctly.
Original Message:
Sent: Feb 12, 2024 09:36 AM
Yes, I know that QoS does not work in simulators. I managed to create a LAB that is using coupe of free ports on our 8325
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/969581c22176475f81377e50a1f72705.png)
The configuration looks like this:
class ip BIURO 10 match udp 192.168.201.0/255.255.255.0 192.168.202.0/255.255.255.0 range 5000 5999 countclass ip LIVESTREAM 10 match udp 192.168.201.0/255.255.255.0 192.168.202.0/255.255.255.0 range 7000 7999 countclass ip MEDIUM 10 match udp 192.168.201.0/255.255.255.0 192.168.202.0/255.255.255.0 range 6000 6999 countpolicy QOS_TEST 10 class ip LIVESTREAM action pcp 5 action local-priority 5 action dscp AF41 action cir kbps 21504 cbs 215040 exceed drop 20 class ip MEDIUM action pcp 3 action local-priority 3 action dscp AF31 action cir kbps 102400 cbs 1024000 exceed drop 40 class ip BIURO action dscp CS0interface 1/1/37 no shutdown ! Auba-CX 8325 does not have apply policy <NAME> out apply policy QOS_QOS_TEST in no routing vlan trunk native 1 vlan trunk allowed 2001 qos trust dscp exitinterface 1/1/38 no shutdown no routing vlan trunk native 1 vlan trunk allowed 2002 qos trust dscp exit
I run an iperf3
with port in selected range on the Stream Server and a wireshark on the Stream DST. The shaping seems to be working , dscp remarking also but not the Priority Code Point (PCP). The frames arrive to Stream DST with PCP field set to 000.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/71af45f7f78b41688a10cbbedc603899.png)
According to https://support.hpe.com/hpesc/public/docDisplay?docId=sf000098776en_us&docLocale=en_US&page=index.html
should mark frames with PCP 3 but it does not seem to work. Do you have any ideas?
-- tommyd
Original Message:
Sent: Feb 11, 2024 04:49 PM
just note that the CX simulator does not support QoS so dont test it there.
yes rate limit policies can be attached to interfaces, lags.
Original Message:
Sent: Feb 08, 2024 03:38 AM
It is applied in interface lag 52 at the end. I did mispaste something because I do not leave this configuration active when not testing. and I was copying things from real switch and GNS3 lab.
interface lag 52
qos trust dscp
apply qos schedule-profile STREAM_schedule
apply policy QOS_WAN out
Is there someplace else to activate the policies?
-- tommyd
Original Message:
Sent: Feb 08, 2024 01:37 AM
you got most of it sorted out. so is the above config snippet for 6300F? and i can't see where are you applying the policies like QOS_WAN, etvc.
here is the 6300 QoS user guide for your reference.
Original Message:
Sent: Feb 05, 2024 06:13 AM
Could you, maybe help me a bit (a lot) in configuring QoS on the 6300 and 8325?
I have one remote office which creates some audio streams. One is a transport stream with several audio channels in it, unfortunately with minimal error correction and it is about 80 Mbps. The other stream is a http steaming and it is about 200Mbps. Those streams then are sent through Juniper EX3300 then some L2 circuit from an operator to another Juniper in central office and then to the receivers. I need to move that streams to an Aruba 6300F in the remote office and a VSX pair of 8325 in the central office. The operator honors CoS tags in ethernet frames. As far as I know I need to:
- classify traffic
- create policies to remark DSCP and add shaping policy
- create queue-profile and schedule-profile ( here I have no idea how to configure this)
- apply policy to the outgoing interface
For now I managed to convert some configuration from Juniper switches but I am not sure if it makes any sense (probably not)
class ip LAN
10 match any 10.x.y.0/255.255.255.0 any count
class ip LIVESTREAM
10 match udp 10.x.z.0/255.255.255.0 range 1000 10000 any count
class ip MEDIUM
50 match any 10.x.q.0/255.255.0.0 x.x.x.0/24 count
policy FC_LAN
10 class ip LAN action dscp CS0
policy FC_LIVESTREAM
10 class ip LIVESTREAM action dscp EF action cir kbps ????? cbs ???????? exceed drop
policy FC_MEDIUM
10 class ip MEDIUM action dscp AF31 action cir kbps ????? cbs ?????????? exceed drop
policy QOS_WAN
10 class ip LIVESTREAM action dscp EF action cir kbps ????? cbs ?????????? exceed drop
20 class ip MEDIUM action dscp AF31 action cir kbps ????? cbs ?????????? exceed drop
40 class ip LAN action dscp CS0
qos queue-profile STREAM_queues
map queue 0 local-priority 0
map queue 1 local-priority 1
map queue 2 local-priority 2
map queue 3 local-priority 3
name queue 3 MEDIUM_queue
map queue 4 local-priority 4
map queue 5 local-priority 6
map queue 6 local-priority 7
map queue 7 local-priority 5
name queue 7 LIVESTREAM_queue
strict queue 7 max-bandwidth 100000 kbps
dwrr queue 0 weight 1
dwrr queue 1 weight 1
dwrr queue 2 weight 1
dwrr queue 3 weight 1
dwrr queue 4 weight 1
dwrr queue 5 weight 1
dwrr queue 6 weight 1
apply qos queue-profile STREAM_queues schedule-profile factory-default
interface lag 52
description Operator
no shutdown
no routing
vlan trunk native 3001
vlan trunk allowed 3001,3011
qos trust dscp
apply policy QOS_ESKA out
-- tommyd
