Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
AOS-CX recommended firmware End of Support
This thread has been viewed 31 times
  • 1.  AOS-CX recommended firmware End of Support
    Posted Jan 02, 2023 06:28 AM
    Hi all,
    Aruba Central recommends a firmware for CX switches that is no longer supported. I have updated my test switch to a newer version and it works.
    Should I recommend my customers to stay on the unsupported firmware or to upgrade to the LSR firmware?
    Bjarne
  • 2.  RE: AOS-CX recommended firmware End of Support
    Posted Jan 02, 2023 09:12 AM
    That does not sound right. The CX switches that I have access to in Central recommend version 10.10.0002.
    Can you ask Aruba TAC to see why Central recommends 10.09 in your case?
  • 3.  RE: AOS-CX recommended firmware End of Support
    Posted Jan 02, 2023 10:05 AM
    Hi Herman,
    thanks for the reply.
    I checked in different customer accounts and it looks the same for everyone.
    Here are two other customers for example:
    I will open a case, but it looks like this is not a problem with any specific account, but a more general issue.
    Bjarne
  • 4.  RE: AOS-CX recommended firmware End of Support
    Posted Jan 03, 2023 03:02 AM
    +1
  • 5.  RE: AOS-CX recommended firmware End of Support
    Posted Jan 11, 2023 04:31 AM
    I got a message from support that they are working with ERT on fixing that problem.
    The recommended firmware branch by support is 10.10
    Bjarne
