ObjectiveThis is the second part of a NetEdit lab series. At the end of the lab series, you will be able to operate an Aruba AOS-CX Network using Aruba NetEdit 2.1.In this lab you will change configurations using the Multi-Editor and create and use change validation tests.
MaterialsIn the attachments you will find:
Attachment(s)
