ObjectiveThis is the fourth part of a NetEdit lab series. At the end of the lab series, you will be able to operate an Aruba AOS-CX Network using Aruba NetEdit 2.1.In this lab you will create a NetEdit Notification and Deploy an NAE Agent, then you will test the NetEdit NAE status monitoring function including the notification log.
MaterialsIn the attachments you will find:
Attachment(s)
