AOS-CX Switch Simulator
AOS-CX Simulator Lab - OSPF v2 Features
This thread has been viewed 196 times
  Thread closed by the administrator, not accepting new replies.
  • 1.  AOS-CX Simulator Lab - OSPF v2 Features
    Posted Jul 13, 2021 10:23 AM
    No replies, thread closed.
    Objective
    The OSPF (Open Shortest Path Protocol) is one of the most popular routing protocols for IP Networks. It uses a link state routing (LSR) algorithm which is performed by every switch router mode in the network.
    This lab should be considered as a basic OSPFv2 lab as an introduction to the configuration and operation of OSPF on Aruba CX switches.
    This workshop introduces OSPF features relating to the use of virtual links and options for using encrypted password between OSPF neighbors for authentication. Other configurations involve the use of the 'passive interface ' command and the 'default-information originate' command.
    The list of features presented in this lab is a very small snapshot of the OSPF features available within the CX software and a comprehensive view of all OSPF features available can be found in the documentation guides from the Aruba Support Portal.
    Materials
    In the attachments you will find:
    • Overview Video
    • Lab Guide
    • EVE-NG Lab Import File
