AOS-CX Switch Simulator
AOS-CX Simulator Lab - OSPFv2 Areas - Basics
This thread has been viewed 316 times
  Thread closed by the administrator, not accepting new replies.
  • 1.  AOS-CX Simulator Lab - OSPFv2 Areas - Basics
    Posted May 18, 2021 10:56 AM
    No replies, thread closed.
    Objective
    The OSPF (Open Shortest Path Protocol) is one of the most popular routing protocols for IP Networks. It uses a link state routing (LSR) algorithm which is performed by every switch router mode in the network. OSPF leverages areas and it is these area concepts that form the basis of the LAB which introduces the 'Backbone area', 'Regular Areas' including Stub areas and not so stubby areas.
    This lab should be considered as a basic OSPFv2 lab as an introduction to the configuration and operation of OSPF on Aruba CX switches.
    At the end of this workshop you will be able to understand and configure ospf areas, understand basic ospf metric calculations of routes, simple route redistributions and the use of stub areas and NSSAs (Not so stubby areas).
    Materials
    In the attachments you will find:
    • Overview Video
    • Lab Guide
    • EVE-NG Lab Import File
