Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
AOS CX suppressing ZTP logs
  • 1.  AOS CX suppressing ZTP logs
    Posted Feb 01, 2023 03:37 PM
    Any way to suppress these ZTP logs?  We are not using ZTP as these switches are all centrally managed.
    2023-02-01T12:43:23.684098-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:43:23.684034-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:43:23.683963-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:43:23.683827-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:32:03.236452-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:32:03.236390-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:32:03.236325-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:32:03.236198-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:18:25.716841-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:18:25.716776-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:18:25.716712-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:18:25.716576-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:06:09.830714-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:06:09.830650-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:06:09.830577-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:06:09.830444-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T11:51:27.763108-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T11:51:27.763046-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T11:51:27.762983-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T11:51:27.762853-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
  • 2.  RE: AOS CX suppressing ZTP logs
    Posted Feb 02, 2023 03:31 PM
    Not sure how I missed this...  https://www.arubanetworks.com/techdocs/AOS-CX/10.08/HTML/cli_6200/Content/Chp_RSyslog/RSyslog_cmds/logging%20filter.htm
    Create a log filter and apply the filter to syslog:
    logging filter remote_syslog_drop
         1 deny event-id 8712-8714,8723,8726
  • 3.  RE: AOS CX suppressing ZTP logs
    Posted Feb 06, 2023 05:27 AM
    If you don't use Aruba Central, you may just stop the central discovery and connection. Seems better to me than suppressing the logs. But be aware that once you want to use central, that the command needs to be reverted.
