Wired Intelligent Edge
AOS-CX Switch 8325
This thread has been viewed 40 times
  • 1.  AOS-CX Switch 8325
    Posted Jun 26, 2021 10:38 AM
    hi
    i have 2 switches 8325 i configured VSX between them and works fine but problem is when i configure multi-Chassis LAG with another devices ( aruba switch 6300 or Paloalto firewall) using ports from 1 to 48 it works fine when one link from LAG is down but when using the 40G ports if one link from LAG down some traffic drops
    Elhosieny Mohamed
  • 2.  RE: AOS-CX Switch 8325
    MVP GURU
    Posted Jun 26, 2021 01:22 PM
    Hi, please provide relevant status results about involved VSX LAG on the Aruba 8325 VSX and about involved LAGs on Aruba 6300 and/or Paloalto Firewall.
    Davide Poletto
  • 3.  RE: AOS-CX Switch 8325
    Posted Jun 27, 2021 05:58 PM
    from both 8325 side it is
    Multi-chassis LAG
    LACP mode active
    vlan trunk allowed all
    vlan trunk native 1
    no routing
    no shutdown
    from paloalto side (one appliance)
    2 port in lag
    lacp mode active
    vlan allowed all
    vlan trunk native 1
    if i disconnect one port for example the one which connected to  secondary 8325
    the secondary 8325 cannot rich to default gateway
    Elhosieny Mohamed
  • 4.  RE: AOS-CX Switch 8325
    Posted Jun 28, 2021 03:51 AM
    Please share:
    show lacp interface multi
    and identify interface number.
    Vincent Giles
  • 5.  RE: AOS-CX Switch 8325
    Posted Jun 29, 2021 06:22 AM
    thank you so much
    the problem solved after upgrading image from 10.02 to 10.04
    Elhosieny Mohamed
