We all know AOS-CX can successfully be used with GNS3, EVE-NG, or directly on top of VMWare ESXi or KVM.
But, if you want to run it in a "Infrastructure-as-a-Code" fashion, now it is officially supported on Containerlab (https://containerlab.dev/), from release 0.44 (https://containerlab.dev/rn/0.44/)!.
You just need to create your AOS-CX container with vrnetlab (https://containerlab.dev/manual/kinds/vr-aoscx/), and then you can create complex networking topologies simply writing a yaml file.
Have a look at this example:
topology:
nodes:
coresw1:
kind: vr-aoscx
image: vrnetlab/vr-aoscx:20230531220439
startup-config: coresw1.cfg
coresw2:
kind: vr-aoscx
startup-config: coresw2.cfg
access1:
kind: vr-aoscx
startup-config: access1.cfg
access2:
kind: vr-aoscx
startup-config: access2.cfg
host1:
kind: linux
image: alpine:latest
host2:
kind: linux
links:
# ISL on port 9
- endpoints: ["coresw1:eth9", "coresw2:eth9"]
# MCLAG between access1 and coresw{1,2}
- endpoints: ["access1:eth1", "coresw1:eth1"]
- endpoints: ["access1:eth2", "coresw2:eth1"]
# MCLAG between access2 and coresw{1,2}
- endpoints: ["access2:eth1", "coresw1:eth2"]
- endpoints: ["access2:eth2", "coresw2:eth2"]
# Link access1 (port 5) - host1
- endpoints: ["access1:eth5", "host1:eth1"]
# Link access2 (port 5) - host2
- endpoints: ["access2:eth5", "host2:eth1"]
Nice, isn't it? 😉
Do you want more? Are you tired of manually configuring point-to-point interfaces and addressing, and creating OSPF or BGP configuration from scratch every time you run a lab?
AOS-CX is officially supported also by netlab (https://netlab.tools/), "the swiss knife for network simulations".
Netlab will help you be more proficient once you decide to drop GUI-based virtual networking labs and build your labs using CLI and infrastructure-as-code principles; it is a "wrapper on steroids" for containerlab (or vagrant/libvirt), which "under the hood" creates a clab (or vagrant) config file, start the lab, and configure your nodes using Ansible.
As an example, if you have the following netlab topology file:
module: [ bgp ]
nodes:
a:
device: arubacx
bgp.as: 65001
b:
device: arubacx
bgp.as: 65002
y:
device: arubacx
bgp.as: 65003
linux:
device: linux
module: []
links: [ a-b, b-y, y-linux ]
and you start netlab, after some minutes you will have an infrastructure running 3 AOS-CX nodes, with P-t-P connectivity, and BGP peering configured.
Easy!
And of course you can extend netlab to load your additional ansible/jinja configuration templates, or take this as a starting point to apply your preferred configuration.
I hope all this can be useful for you how much it was for me 😉
