AOS internal DB multi user addition with generated passwords
  • 1.  AOS internal DB multi user addition with generated passwords
    Posted Dec 05, 2017 04:51 AM
    Hi all,
    It’s pretty much what the subject says, is it possible to add a bulk of users to the internal DB with randomly generated passwords and be able to export the user/password list later?
    The GUI allows you to add users one by one, with the option of generating a password per user. CLI allows to add multi users at once by copying them from a spread sheet with the "add user" command but you have to add a password for this command to work.
    How can I add my list of users and generate passwords for all (and view it later)?
  • 2.  RE: AOS internal DB multi user addition with generated passwords
    Posted Dec 05, 2017 05:48 AM
    You can add a random user on the commandline like this:
    (Aruba7640-US) #local-userdb add username user1 generate-password
    GuestConnect
    Username: user1
    Password: EIII9029
    Start date: Tue Dec  5 04:46:00 2017
    Expiration: none
    You can just type "encrypt disable" and then "show local-userdb" to see all of the usernames and passwords:
    (Aruba7005-US) #encrypt disable
    (Aruba7005-US) #show local-userdb
    User Summary
    Name   Password   Role           E-Mail  Enabled  Expiry  Status  Sponsor-Name  Remote-IP  Grantor-Name
    test   test123    guest                  Yes              Active                0.0.0.0    admin
    user1  EIII9029   guest                  Yes              Active                0.0.0.0    admin
    User Entries: 3
