AOS path from 6.4.3.11 to v8 on 7220
  • 1.  AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:23 PM
    In order to accommodate our new 303H APs, I'm looking to upgrade our 7220 controllers to AOS8. Our two controllers (master/standby) are running 6.4.3.11. Is there a preferred path to v8? I have a few maintenance windows to work with so I can go to 6.4.4 and 6.5 first if it helps.
  • 2.  RE: AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:26 PM
    303H is only currently supported on 6.5.2.x
  • 3.  RE: AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:32 PM
    The spec sheet says ArubaOS™ 6.5.2.0/8.2.0.0.
    http://www.arubanetworks.com/products/networking/access-points/303h/
  • 4.  RE: AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:33 PM
    AOS 8.2.x is not out yet
  • 5.  RE: AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:36 PM
    On the path to 6.5.2 then, can I upgrade directly to that version or should I go through 6.4.4?
  • 6.  RE: AOS path from 6.4.3.11 to v8 on 7220
    Posted Jun 05, 2017 03:57 PM
    You can upgrade directly to AOS 6.5.2.x from ArubaOS 6.0.1.0 or later version of ArubaOS 6.x
