AOS point to point: Can't ping device behind point AP
  • 1.  AOS point to point: Can't ping device behind point AP
    Posted Jul 20, 2017 02:50 AM
    Hi All,
    I am trying to create a wireless point-to-point connection.
    I used the template on ASE for this. Now my point to point connection is up. I am also able to ping the POINT-AP. Behind this AP is a switch, but i am unable to ping this switch. I have added the VLAN on the controller where the IP of the switch belongs to.
    I think i should be very basic, but i don't see it.
    Does someone has an idea?
  • 2.  RE: AOS point to point: Can't ping device behind point AP
    Posted Jul 20, 2017 03:37 AM
    Problem solved. My though was from the controller (because with an accesspoint everything is tunneled). Forgot to allow the vlans on the switch where Portal AP was connected to.
