AOS-S Switch Named VLAN enforcement with ClearPass
  • 1.  AOS-S Switch Named VLAN enforcement with ClearPass
    Posted 7 days ago
    I am setting up a 2930F switch for wired authentication with ClearPass.  There will be multiple locations that use different VLAN IDs at the different locations.
    Example Location 1 MGMT VLAN ID is 100
    Location 2 MGMT VLAN ID is 200
    Location 3 MGMT VLAN ID is 300
    I have the enforcement currently working in our test environment if I use the standard VLAN enforcement profile to assign a VLAN based on the NAD ID.
    Is there a way to assign an enforcement profile to use the named-vlan so we can reference the name in the enforcement profile and each switch will use that to place the user on the correct VLAN ID for that switch?
    I know I can use the DUR template but that may not be an option for this customer.
  • 2.  RE: AOS-S Switch Named VLAN enforcement with ClearPass
    Posted 7 days ago
    There is this attribute  from "Radius:Hewlett-Packard-Enterprise" that could help.
    Egress-VLAN-Name: Configures an optional, egress VLAN for either tagged or untagged packets when the VLAN ID is not known
  • 3.  RE: AOS-S Switch Named VLAN enforcement with ClearPass
    Posted 7 days ago
    Hi
    In your enforcement profile that sends the VLAN ID, just replace the number with the VLAN name instead.
    Edit the attribute Tunnel-Private-Group-Id and enter the name.
    The name is case sensitive, so make sure to type the name with the same case on both the switches and in the ClearPass enforcement profile.
    Best Regards
    Jonas Hammarbäck
    MVP 2023, ACCX #1335, ACMP, ACDP, ACP-Network Security, ACEP, ACSA
    Aranya AB
  • 4.  RE: AOS-S Switch Named VLAN enforcement with ClearPass
    Posted 6 days ago
    Hi Jonas,
    This is great info, thanks so much I will give it a test tomorrow.
    Thanks!
  • 5.  RE: AOS-S Switch Named VLAN enforcement with ClearPass
    Posted 4 days ago
    From our testing we ended up configuring DUR enforcement profiles and using the named VLAN with the role.  Trying to use the HPE radius attribute did not seem to work as we saw the user ended up in the default VLAN.  We also tried using the named VLAN in the Private Tunnel Group ID and the user also ended up in the default VLAN.
    DUR seems to be the way to go on this one.
