Wired Intelligent Edge
AOS-SW, Port profiling based on OUI
  • 1.  AOS-SW, Port profiling based on OUI
    Posted Nov 26, 2021 11:08 AM
    Dear Gurus,
    is it possible to apply profile on the port based on OUI part of MAC address of connected device?
    Switch is 2930F. I've tried this:
    device-identity name "Mitel"
    lldp oui 00085d
    exit
    device-profile name "Mitel-Profile"
    untagged-vlan 8
    tagged-vlan 30
    exit
    device-profile device-type "Mitel"
    associate "Mitel-Profile"
    enable
    exit
    The line "lldp oui 00085d" do not work. Everything else does (checked with changing the line to "lldp sys-name "Mitel IP Phone").
    I've tried "lldp oui 00085d sub-type 1" with no avail. I suppose this TLV is not included in LLDP frame from the phone. I don't know how to check it (I would use Wireshark but the switch is not in my possession).
    Is it somehow possible to use part of PortId from LLDP (which is, in fact, OUI):
    # sh lldp info remote-device 1
    LLDP Remote Device Information Detail
    Local Port : 1
    ChassisType : network-address
    ChassisId : 10.1.8.13
    PortType : mac-address
    PortId : 00 08 5d 6d a5 0b
    SysName : Mitel IP Phone
    System Descr : Mitel IP Phone
    PortDescr : port 0
    Pvid :
    System Capabilities Supported : bridge, telephone
    Can someone, please, clarify this for me? Maybe there must be a completely different approach?
    Alexander Suntsev
  • 2.  RE: AOS-SW, Port profiling based on OUI
    Posted Nov 26, 2021 06:25 PM
    LLDP oui is not the same as MAC oui
    in your pcap, look for LLDP packet with organization specific TLV (type =127)
    you need to match it with this value, note that the screenshot below is just a sample not the value for mital phones.
  • 3.  RE: AOS-SW, Port profiling based on OUI
    Posted Nov 29, 2021 03:25 AM
    Thank you. I see your point. I don't have a pcap to look at it. Maybe there is a different LLDP oui which can be used, but.. a customer has a various endpoint devices all of which has a common MAC oui "00:08:5d". On other vendor's switches they use this part of MAC to apply voice vlan to this and only this devices. So they want to copy that logic to an Aruba switches. Can you tell is there a way to archive this? Or LLDP oui, SysName or System Description is the only options (without involving ClearPass)?
    Alexander Suntsev
  • 4.  RE: AOS-SW, Port profiling based on OUI
    Posted Nov 29, 2021 04:47 AM
    yes I think that what you need with device profile approach.
    however you can also do the simpler way of having voice VLANs and using LLDP med to put the IP Phones in the voice vlans.
    I think LLDP is globally enabled b default.
    VLAN 10 is for VOIP Phones, VLAN 21 is for PC and 1-12 are Switch port numbers.
    Here is the sample config snippet
    vlan 10
    voice
    tagged 1-12
    vlan 21
    untagged 1-12
    here you can find more explanation on it and device profiles.
    https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedAssets/VoIP_Deployment_on_ArubaOS-Switch.pdf
